Holley model 2300 ,list 0-4792. Trouble finding a float #. Anyone familiar. Thanks -Mike
going to try that simple check with the bleed holes - if it is set correctly it won't increase or decrease ? Think end carbs still have the plugsSince I have a 440 6bbl, a couple of questions:
Are your outboard carb idle mixture screws accessible, IOW no lead plugs? Having those adjusted properly was a HUGE part of getting my 6bbl dialed in.
Reading this tuning tip was THE epiphany for dealing with the biggest hurdle in having a great running, idling 6bbl:
If I couldn't have adjusted the outboard carbs, my 440 would never have run properly. When I had my running Holley carbs modded by Promax, to accommodate current motor mods and even more importantly, future significant mods, I had the angled idle mixture screws throttle plate installed in the rear carb.going to try that simple check with the bleed holes - if it is set correctly it won't increase or decrease ? Think end carbs still have the plugs
Correct. If it does change, for your own sake, remove the lead caps and gently, ever so slowly and MUCH more slightly turn the idle screws on the outboard carbs! They are WAY more sensitive to adjustment! I knew the outboard carbs were a problem when I bottomed out both idle mixture screws on the center carb metering block and the engine ran better.if it is set correctly it won't increase or decrease ?
I didn't have any problems, BUT I have also read that.the outboard carbs I've read that the needles are frozen in place.
