Evan Dutch
Hi
I’ve recently purchased an atlas 10k capacity asymmetrical 2 post lift. I’m currently setting it up in my 24’ deep by 30’ wide shop (actual useable depth is about 23’). Id like to set the posts so that if need be I can lift a crew cab long bed truck (it’ll be tight but if it’s set right I think it’s doable). Does anyone have a shop similar in size to mine? And if so, do you have a lift? What’s the largest vehicle you can fit on yours?
thanks
thanks
