Cudafever
- Joined
- Sep 27, 2009
- Messages
- 4,870
- Reaction score
- 1,990
$100 buck to the first on to get here. will not ship.
Ok for the details complete eng, including heads, intake and exh manifold and Flywheel.
Was running when came out of......71? ramcharger it has been in my garage for the past 10 years. Was going to build a stroker out of it someday..........Today it need to go because i can't take it with me.
There is some surface rust on cyl bores but the pic im showing, the clean spot, is were i rubbed the rust of with my finger. It has been in my garage cover up this hole time.
It is a steel crank 400, but as i said i was going for a stroker and didn't care that much.
It ran grate! HOW EVER! IT WOULD GO THRU A QUART OF OIL IN A HUNDRED MILES (Rings collapsed.) Didn't smoke that you could see, but, if you were behind, on the freeway you sure could smell it. Here's some pictures......Oh it resided at 82930 zip code.
