RabidScott
So I was putting my front end back together after replacing all the bushings and steering box.... other than the typical spinning LCA pins with the poly bushings it all went back together pretty okay.... except the passenger side control arm is pushed back on the pin. Driver side is okily dokily, everything is as it should be.
I can bang on it with a hammer and it moves forward a bit then slides back. Still nowhere near where it should be.
Then I remembered this when I disassembled it: the rear strut rod bushing was halfway through the hole!! You couldn't see it when the nut was tightened but sure enough...
I used Energy Suspension bushings and trimmed the backside back on both rear bushings as I've done before but I don't think that's the culprit as the drivers side all went together good and I double checked the bushing placement...
Is there a possibility it has the wrong strut rod?
Maybe another year/body style car's strut rod made it onto this car? Maybe a B-E Body?
If the strut rod checks out correct, what next?
Everything has been fighting me on this stupid car. Even my 2 year old little girl is calling it "stupid car" now...
