[SOLD] 71 340 engine for sale
HotRod20
Plymouth, MI
BUMP: Parting OUT- a 71 340 engine for sale VIN is 1B156652 cast date is 11-19-69 engine ID :
GW 340 P 3352 0461 A. This is a factory .020 over block with 10.5 pistons, stock 340 cam and lifters in order of disassembly.(8) factory bushed floating rods that have been re-sized #3418645.Have paperwork for the work on the rods. Block has been degreased and Magnafluxed. NO Cracks. Have paperwork for the work done.
The following is included with this sale. Main caps, steel crank 010/010 and flexplate. Oil pan, pick up and oil pump,windage tray. 1-O head dated 10069 1- Z head dated 11129.Part numbers on both are 3418915, 2.02 intake valves. 72 Thermoquad #6090,idle mixture screws turn freely. Main bearings and cam bearings were dated 2-70 upon disassembly.
Valve covers,rocker shafts,pushrods, timing cover#2951 698, #216 fan, correct intake #3512100, Also included is a Torker 340 intake, Fasteners include:crank dampner bolt,driver /pass side head bolts,valve cover bolts,intake bolts,timing cover bolts,crank pulley bolts, dipstick tube.P/S mtg.bracket with bolts. $1,850.OBO, I can deliver to Carlisle if prepaid,or Pick up in Plymouth MI. 48170.
Serious buyers only need inquire by PM. Thanks
HotRod20
BUMP:
71 340 engine assembly parting out:
.020 Factory Block with main caps, Magnafluxed with paperwork and Degreased Clean No Cracks-$600.00
340 steel crank .010/.010 ***SOLD***
Oil pan, windage tray and pickup ***PENDING**
#2100 71 340 intake ***PENDING***
Torker 340 intake $150
Valve covers ***PENDING***
original 340 camshaft and lifters $50
.020 factory 10.5 pistons with pins $80/8
Resized Floating Rods $ 100.00 /8
2.02 Heads, one is a O head one is a Z head $400 pr.
Timing cover $40
72 #6090 Thermoquad $100
All prices + plus shipping,.. or delivery to Carlisle with pre-paid parts.
PM me for questions or additional information.
Cashiers Check, Money order, US Postal Money order, sorry..no pay pal.
HotRod20
BUMP:
.020 Factory Block with main caps $600.00
340 steel crank .010/.010 $175
Oil pan,windage tray and pick up $100
#2100 71 340 intake $175
Valve covers $100 pr.
Timing cover $40
HotRod20
Have rods been run since resized? What rod bolts?
