Mymopar.com, download your cars factory service manual.
Its all in there.
I suspect you pull the steering wheel, then some screws for the turn signal switch, then most likely some screws or a set screw or the like.
If you are asking about removing it completely, i suspect you will have to pull the column.
Its all in the FSM
