Ok guys, lets talk ECU's
I have been testing a bunch of different ones on a mock up with the distributor machine. Scope, meters etc. Biggest issue with a bunch of them is they draw around 4 amps in the on position which is alot of heat and around 2 amps running, try not to turn the key on and not running.
I'm happy to have bought one of your tested chrome boxes. With my sig gen and O'scope, It's perfect. Paul.
Go FBO. Will have to bypass the ballast resister and get a 1.5 ohm coil. Has an adj rev limiter. Get a good set of Petronics Flame thrower wires, I bought the porcelain plug end ones.
