Help identifying 1969 340???
Veryfastdart
Hampton NH
Are these def 69 340?
Thank you
Id say yes, they look like mine...
No heat shield on passenger one..they are for 2bbl 318...not 340
I know 68 340 had heat shield/loom to protect the wires from the choke boss on the 340. Probably the same for 69
I believe they are 68 340 . The left side is 4bbl. It has the high plug wire holder for the 4bbl throttle bracket. I had early 68's without the wide wire loom on the right side.
You can tell what year left side you have by any original paint left on it. Red is 68 turquoise is 69. see if the original colors match from side to side. 68's far less out there. You can make a set of early 68's by using a left 69 340 and a right 69 318.
As noted, they are missing the "heat shield" wire loom protector on the passenger cover. These are '69 x 340 covers.
There is a correct set for sale right now posted today for $175
