[SOLD] 68 Dart GT
DARTGAME
SuPeRcHaRgEd
santa barbara,ca
$8900.00 obo
1968 Dodge dart GT originally /6 with bench seat
1970 318 .30 over with Mancini rebuild kit by sealed power
Floating pins and chrome moly rings
Comp cam EX262
302 heads with ferrea stainless valves 1.74/1.50
Edelbrock performer intake
Holley vac secondary 750cfm
TTI step headers
3” TTI exhaust with one chamber flowmaster mufflers
Holley mechanical fuel pump
Mopar performance distributor
MSD 6A ignition w/ blaster 2 coil
MSD 8.5 wires
Moroso air cleaner
Edelbrock chrome valve covers
Chrome oil pan
Schumacher engine swap mounts from /6 to V8
Flexolite flex fan
4 core radiator
Manual steering
Flaming river power steering to manual steering adaptor w/ universal joint
New turn signal switch in steering column
Complete new engine harness from Year One
CRT transmission w/ reverse manual valve body
Steel braided transmission cooling lines with Earls fittings
Trans cooler
New driveshaft using large 1350 joints
8.75 rearend w/ 741 case 3.55 open center section with doctor diff 1350 flange
Yukon axles with green sealed bearings
Summit racing rear disc brake kit
Master Power front disc brakes with booster
KYB shocks at all four corners
Rear diff has perches welded on if want to go inboard to frame
Mancini 3/4 offset rear spring shakle/hanger kit installed
New fuel level sensor 5/16
Bench seat from 1969
Poly rear leaf spring bushings
Front end rebuild except for lower arm bushings
Large bolt pattern all the way around 5x4.5"
New napa alternator with lifetime warranty
New voltage regulator 69 model year and up
2500 stall converter unknown make
New black dash cap
Autometer 2 1/16 gauges mechanical oil/electric temp,temp set up/ volts
Mopar performance mini starter
CAT SFI solid flex plate*
Sound/heat barrier installed on floors
Grant tuff wheel
Body needs attention:
Trunk floor has rust, will need to be patched or replaced due to moisture(new trunk floor included)
Fenders have dents along with small dent on left side roof line
Right rear lower quarter has some rust pitting through
Seat belts original but not to vehicle from another 68 A-body
Original a/c car but all components long gone, fire wall sealed off but not butchered
Original engine and transmission gone now V8
Door panels/sun visors / lower dash vinyl dyed black
All emblems present but side mouldings gone
Front and rear bumpers need re- chrome, driver quality
Right front fender/hood/trunk lid not original to vehicle
Fender tag present but no build sheet
Original black CA license plates
Fuel gauge and amp gauge work in cluster, temp does not
Vehicle will need new park brake cables for rear calipers for emergency brake
Have title in hand, is currently CA registered
Vehicle is located in Santa Barbara / Ventura CA area 93003
Pm for info and more pictures
Car runs and drives great
