Want clean plastic storage storage boxes to store and ship Mopar 8 3/4 chunks most say 9 inch ford. Jegs, summit, spreedway
I am afraid that one is also for the Ford 9", and if you look at my photos, you will see the 8-3/4 comes close to falling through the hole in the 9" round case. I find the rectangle box is also much easier to hold and carry.
Thanks, I called their tech support and asked for some measurements on that one. They’re supposed to get back with the diameter of the round opening and the height above and below the opening. You’re probably right but I figured I’d ask. Most likely the box style will be the one. Glad to see that one will work for sure.
Igloo cooler ratchet strapped to a pallet. You can get free pallets and cut them down to size.
I use a 5 gallon bucket. I put a piece of plywood in the bottom and cut an x in the top for the pinion to stick thru. Then wrap tape around the x and yoke and around where the top snaps to the bucket. Also tape the bucket handle down.
I leave the handle up and write heavy on the top and lug it ti the ups store
For shipping, the person moving the container from truck to door step ( and all points between) will drop the container rather than set it down.
That goes for 99% of all shipments, so package accordingly so it can survive a 2 foot drop
Amazon.com
So is this the one that fits the Mopar 8 3/4? I do not want a cheap one time bucket. A new clean container that is clean and don't dump over in my trunk, the wife's trunk, or friends cars transporting a 3rd member.
I just want one or two clean ones to transport pigs when we do so. The wife or friends cars, mini vans ect. Was asking about the new clean stuff asked about in post 1. Not some possible mess of a bucket.
Looks like the only one that fits is the Moser rectangle black one.
Since most things are made by same companies and rebadged/sold wonder if the Speedmaster is same as Moser
Thanks
IMHO I would stay away from the nose up type and look for on its side type, with as wide a base as posible
Thanks.
That's what I was looking for as noted in my earlier post.
The box style, that lays flat. The stand up box lid one would have worked if was only one that fit 8 3/4 as last resort.
Looks like the Jaz is to short but wonder about the one I posted from Speedmaster?
The one you listed appears to be the same one I posted pictures of.
I ordered the Amazon one looked like the one in post #21
i used a gift card balance should here it in a week or less. Will shoot pics if fits. Thanks.
It looks like the Moser one posted in post #21 he said fit. So hoping same company makes Moser ones too. You know how that goes, a company makes stuff and is sold by many. Problem if figuring it out sometimes (like now)
Thanks
Well Amazon dropped the boxes off. I had a gift card burning a whole in my wallet so used part of it.
8 3/4 fits but is tight.
Perfect for what I wanted. To keep pumpkins from rolling around.
Fits good and tight so no rolling around inside.
And keeping what ever trunk, mini van insides safe and clean during transport. Both pics of box with top on had the pig inside.
The one thing I did not like is has a spot to put label if used to ship. As it has their return address printed on it.
Has anyone tried putting the center section in upside down?
I know it's the same dimensions but the yoke might be able to sit up a bit and provide a tad more room?
My picture is one way, and Musclesigns is the other
I went and flipped mine like 340six but had a bit of interference with the yoke. Either way seems fine with me. I don’t plan on shipping it but want a clean self contained container for long term storage for freshly rebuilt chunk.
