Flex plate for 5.9 and 904
remytherat
Los Angeles
Researching parts for my 5.9 swap into my dart which has a 904. Looking to keep the stock converter.
Since the b&m flex plate is out of production, what are my options? I've heard some of the 5.9 magnum flex plates can be made to work (97 and up??) with a neutral balance 904 converter. Looking for cheap.
Yes, a stock 5.9 flexplate works. That's what I'm using. Seems like I had to oblong one hole though. Darn memory isn't as good as it once was!
When I was running a 904 I used the stock 5.9 flexplate from a 96 and later truck. One hole needs to be opened up maybe an eighth of an inch to allow it to mount to the 904 converter.
