Some pictures of clutch pedal Assemblies
Oldmanmopar
Going left turning right
Danielsville Pa. 18038
I am getting pedal assemblies together to go with the rest of the clutch linkage I have. I thought I would post some pictures for reference for those who would like to identify pedals.
The pedals with the red springs are 70 -71 heavy duty with 5 3/4 pin spread taken from 340 cars. The clutch pedal also has needle bearings instead of plastic bushings.
The set with the blue spring is a standard set with 5 1/4 pin spread taken from 70 -71 slant six car. Plastic clutch pedal bushings.
The set with the spring removed for use with a diaphragm style Pressure plate is for 63-66 A-body That also has a 5 1/4 pin spread plastic bushing.
Seeing them side by side should help members identify Heavy Duty from standard sets.
Nice pics. I've always used Brewer's website to help ID various clutch/pedal/trans parts. Now I just need to figure out how to store a convenient link to this thread or PDF it somehow.
Is this the HD as well? Has what looks like the bigger spring but I don’t see the same cover over it like in the pictures you posted.
Wish there were better pictures but this is the best he had posted lol.
Not sure what that is for, the spring doesn't have the outside brace.
