GO Green 69 Dart Conv. 340-6pak
1969 Dodge Dart GT Convertible. 1970, 340-6pak. Out of box carbs. 372ci, Edelbrock heads, Bullet .530 lift hyd. roller. Weisco forged 10.25 pistons. Head, Main studs. Eagle rods, Crank. Cast iron Flow Cooler pump, with A/C (had to make the brackets), custom one off water neck, TTI 1 7/8" primary headers. Moroso 7 qt pan. MP ignition (recurved). Harland Sharp rockers/shafts. Griffin Radiator. 727 kevlar clutches, 5.0 kick down,Turbo Action forward valve body, Turbo Action...
2fine69s
Rating
5.00 star(s) 4 ratings
