‘75 Duster drivers side vent?
No the panel goes in beside it. Here is mine the panel is removed but you can see where it goes
Mine is a dart but dusters should be the same
Silly question, but did they take these fresh air vents out on 76 models? My 76 doesn't have fresh air vents and I don't see where they would be.
Thanks,
Joe
Thanks,
Joe
That’s why I asked the question. I have a 71 that has a circular opening in the left corner under the dash and that’s where the vent attaches. It’s not there on the 75. I see a hole on the side near the top where the kick panel would go. I though maybe the air from the cowel was routed that way. As you can see in the picture, this is under the left corner of the dash, there is no hole. There is a small hole above and behind the fuse box. (I couldn’t get a picture of it). I thought maybe that fed a vent in the kick panel. Ugly under there.
My 75 Duster has no driver vent. There is no opening in cowl on that side. Maybe cause it has AC- mine does..
Think thats the difference,with ac cars no vent.
Should be extra holes in firewall near heater hoses. fender tag may tell.
