[SOLD] 05 5.7 hemi/75mm turbo and turbo system
junior636
Grand Rapids, MI
05 5.7 hemi, bullseye 75mm turbo with t4 housing, turbo smart wastegate and blow off valve. Hot and cold side piping for a body dodge. System does require trimming and fitting of the bumper brackets, grill and blinkers. Engine is fresh with new rings gapped for boost @ .028, all new main bearings and rod bearings, push rods, pulleys, water pump, alternator, coil packs, comp cam and springs, comp cams adjustable timing set and milidon a body center pump oil pan. Have dump for exhuast built, it just dumps at the frame but could be built on to. Still needs injectors, spark plugs, serp belt and the oil lines for the turbo ran. I have a bbk ford throttle body for it. $4,000, will not take less. Located in Coopersville Mi.
