[FOR SALE] 1/2 Dozen 426 Wedge Blocks
GTX JOHN
Boulder City NV.
These all came out of Tri City Performance. Greg Luneack (RIP) was a close friend
and one of the very top Max Wedge engine builder and National Event winning
Max wedge Stock/SS racers of the last several decades. He had a complete machine
shop on premises and did all work himself. He is truly much of the reason for my success over
these many years!
One 426 Unique Block. It is Standard Race/Industrial/Nascar?
factory set up for 4 Bolt Mains and lots of extra webbing and features
It is very heavy compared to the other blocks,RARE RARE
See Discussion of this in Racers Hangout in both A/B today.......................$1,250.
Several 426 Standard Production Blocks...................................................$750.Each
One 440 .030........................................................................................ $650.
Two 413 Standard (I cannot get to it yet to see Industrial) .......................$400.Each
One 1963 Bare 426 Max Wedge (286) Head..............................................$475.
He has Acid Washed/HotTanked Magged and Pressure/Sonic Tested nearly
all of the blocks prior to putting them in inventory to be built by his shop. That
work alone has often cost me $400 to $500 anymore = now that
he is deceased.
Several Full Race prepared 426 blocks built for stock or Superstock.
Bushed Lifter Bores/Decked on C/L. Bored With deck plate with
hot water flowing. Partially filled with Block Hard/Main Studs They are his
personal engines as I understand for one of his cars and I am
selling them for less than the machine work costs = let alone finding
a 426 block that Sonic tests well enough for competition....................................$1,950.Each
One used 426 plus 030 used Short Block. 1963 Model Year car AAQA Block.
11 to 1 TRWs. Solid Max Wedge Camshaft/Lifters. Timing Chain/Cover.
Not broken but could really use refreshening.
Less Head/Intake/Carbs............................................................................$1.500.
One matched Pair of 3705SA 1964 Max Wedge Carbs off one of his A/SA cars.
I will check them out and take apart for inspection and assemble.
I will replace needles and seats and Accel pumps as needed
I will include two new in the box rebuild kits for them.
One of the does not have a legible # but the are identical 3705SA..................$750.pr. or $650. without
me going thru them
These are not my stuff and that is all I know about this stuff.
That is why they are way less than I would ever sell my personal
stuff!!
These parts are in my trailer at my shop and I am the Seller.
This stuff is right by the trailer door and I will dig out many other
parts further back when I am able to do so.
I get to So Cal and could deliver for free.
Also will deliver to Nevada (Free in South Nevada) and Arizona
for the cost of Diesel.
Can you get pistons for these things
Very easily available and a off the shelf item.
Same for rings. (4.25 Bore is very common as
well Ai is 030/040/060/070 on this bore size.
Many guys just eventually bore them to 440 Standard (070)
if they Sonic well and Greg would not have kept
them for years if they did not sonic very well.
All 426 Production Blocks are sold
The 426 Max Wedge Shortblock is sold =
When I cleaned the grease off it the cylinders
were great and did not need rebuilding.
When I crawled in the trailer = the 413 Blocks
are indeed Industrial Blocks with the extra ribbing
and thickness. Gregg: Acid Washed/Hot Tanked/ Magged
and Sonic tested all his stuff before setting it aside to
build for racing. He carefully selected the blocks he kept
for himself.
They are standard 4.19 Bore.
In my stockers I generally bored them 4.28 and some
of the bracket engines were 4.32 and still thick.
The race 426 finished blocks are all made out of 426
Industrial blocks with the extra ribbing and thickness. They
are fully machined with ARP studs. However, they do not have
and casting numbers on them but I believe that is how they were
cast (I have only seen a couple in my life).
I have dropped the price on these to $1,500.00 (your choice).
I will try to get all the cranks out next week. There are some Max Wedge
cranks in there.
I will listen to offers on what is left from the ad.
I have plenty of pallets and can ship on your dime.
Twenty more feet of parts in the trailer to get next.
However, leaving to race in Arizona in the morning for a
week again.
There are also a 1/2 dozen 440 Bare blocks (Many HP) $375. each
further back in the trailer and a complete 72 440HP carb to pan $950.
I WILL get everything out in April and there is a ton more!!!
Finally got all the blocks out today and a lot of other stuff as
well. I can take pictures of any of the 426 Blocks or 413s now.
I can pallet them up and take to Fastenal or shipper of your choice.
On the two 426 fully machined race block only = I will split the cost
of shipping if that helps. Or pay all of it if it is $400.00 or less (Probably
Fastenal only in western states).
These blocks and another dozen 383 and 440 blocks
and complete engines and short blocks. Discounts if
you buy more than one!
