Tomsecks
Active Member
Have a LA engine 10.5" Hays Borg & Beck style clutch with an aluminum flywheel & ARP pressure plate bolts. Used but in good shape, has been balanced with the flywheel. Flywheel is a custom segmented insert design - Google "cyn-r-g" flywheel for details. Is a piece you don't find made for Mopar applications but works very well.
Clutch has been "tweaked" by Hays; my brother used to work there and built this one with some beefier components - so it's ~ 20% more gripping power than the standard Hays model.
Does NOT have a Mopar disc - had this mated to a Tremec TKO so it has a GM spline, not a 23 or 18 spline Mopar. I'll throw the disc in if you want it - perhaps somebody is doing a TKO swap???
Asking $300 - PM here
