[SOLD] 10 and 11 inch brakes
rbkt65
jerseyville, illinois.
complete both sides. 10 or 11 inch backing plates(blasted and painted). has new brakes, w/cyl, hardware and self adjuster kits. choice of 10 or 11 inch set up. the 10 inch should ship in the large usps flat rate box. 11 inch will be judgement call by usps if box does not close properly. 225.00 EACH shipped to lower 48. pm determines place in line.
will they work with my 10” drums that have 10 x 1 3/4 in them now?
I doubt it. They are wider than what you have now. If you were to get drums for 2 1/2 inch shoes, you could use them. Another concern is whether you have big bolt pattern or small bolt pattern.
Big.. let me check on the drums.
