stop the beast
My factory drums were 10 x 1.75 and I plan to use the guts with new shoes but I'm using the backing plates from an 8 3/4 housing because they are OEM with 5-bolt holes to mate to the 8 3/4 housing I've installed.
My question is will my 10 x 1.75 parts bolt up to this backing plate, it's slighty different? All mounting points/holes (for hardware etc) are the same. The difference is two little "tabs" on the welded on piece around the wheel cylinder. I have no idea what these are for in my setup or the larger 2 or 2.5 setup.
Check out the pics. All other features are identical between the old and new plates.
New plate, focus on the area right under the wheel cylinder cutout:
Old:
Old:
