10 inch Brake Backing Plates - Simple Source?
jb123
Active Member
USA
10 inch Brake Backing Plates - Source?
Usual issue - I switched the 8 3/4 to a big bolt axle and I need some brake backing plates with the deeper offset.......etc.....
Where can I get some of these? Does anyone repop these things so I can just call em up?
Also if anyone has a list of 1989 and earlier Mopar CARS with 10 inch rear drum brakes big bolt pattern pls put it up
Thx - JB
I got mine from the local salvage yard. You also need the spreader (strut) that goes between the primary and secondary shoes. All the other parts are readily available from any parts shop.
http://www.doctordiff.com/mopar-10-x-2-1-2-drum-brake-assembly.html
It seems as though you can use Dodge Dakota 10x2.5" rear brakes because my friend's 8 3/4 he bought had the guts for a 1997 dakota in them so we had to use those shoes. Once we bought the shoes (the parking brake strut is different), they went right on. Might be worth a shot. You'd just need the outer drum for something like a 74 Duster.
Sure, if you want to pay too much and receive lousy service! :violent1:
Mother's Mopar has a set of 11x2.5" loaded plates on eBay. I've bought from them before and they're awesome. If you have 15" rims, the 11x2.5" drums are the way to go. They do fit some 14" rims, I have a set of magnums on my Dart right now as rollers and they clear the 11x2.5's, and that's with the heavy duty finned drums too.
http://www.ebay.com/itm/11-2-5-PLATES-LOADED-MOPAR-DODGE-PLYMOUTH-8-3-4-DRUM-BRAKES-8-75-NEW-YORKER-/272132377012?hash=item3f5c5a89b4:g:wsEAAOSwUuFWvlht
Can't you get one from any B or E body?
Yes. And from any of these. I highlighted the ones that run the latest, ie, easiest to find in the yards. This isn't a comprehensive list, but it's what shows up on RockAuto as compatible.
10x2.5" drums with BBP
CHRYSLER CORDOBA 1975-1983
CHRYSLER IMPERIAL 1981
CHRYSLER LEBARON 1977-1981
CHRYSLER NEW YORKER 1979
CHRYSLER NEWPORT 1979-1980
CHRYSLER TOWN & COUNTRY 1977-1981
DODGE A100 1964-1970
DODGE A108 VAN 1967-1970
DODGE ASPEN 1976-1980
DODGE B100 1971-1980
DODGE B150 1981-1989
DODGE B200 1971-1980
DODGE B250 1981-1989
DODGE CHALLENGER 1970-1974
DODGE CHARGER 1966-1974
DODGE CORONET 1965-1974
DODGE CUSTOM 1965
DODGE D100 PICKUP 1970-1987
DODGE D150 PICKUP 1977-1987
DODGE DART 1973-1976
DODGE DIPLOMAT 1977-1989
DODGE MIRADA 1980-1983
DODGE RAMCHARGER 1978-1983
PLYMOUTH BARRACUDA 1970-1974
PLYMOUTH BELVEDERE 1965-1970
PLYMOUTH BELVEDERE II 1965-1967
PLYMOUTH CUDA 1970-1974
PLYMOUTH DUSTER 1973-1976
PLYMOUTH GTX 1967-1971
PLYMOUTH PB100 1975-1980
PLYMOUTH PB100 VAN 1974
PLYMOUTH PB150 1981-1983
PLYMOUTH PB200 1975-1980
PLYMOUTH PB200 VAN 1974
PLYMOUTH PB250 1981
PLYMOUTH ROADRUNNER 1968-1975
PLYMOUTH SATELLITE 1965-1974
PLYMOUTH SCAMP 1973-1976
PLYMOUTH TRAILDUSTER 1978-1981
PLYMOUTH VALIANT 1973-1976
PLYMOUTH VOLARE 1976-1980
And then there's these. This is the list for 11x2.5" BBP drums. Again, probably not all inclusive, and with these sometimes you'll find they have 10x2.5" drums as the 11" drums were an option on some.
The 5th Ave's and Diplomats are great sources. The van's on this list almost NEVER have the 11" BBP drums, they mostly used some 9 1/2" drum that's pretty much useless. But the 11x2.5's were an option.
Also, not on this list are the heavier trucks that used a 5x5.5" bolt pattern. The 11x2.5" brakes and drums that ran the 5x5.5" pattern are the same as the 11x2.5's with a 5x4.5" pattern except for the bolt pattern on the drums. So, the backing plates and everything will work, you just need different (or re-drilled) drums. Just the 5x5.5" pattern though, anything with an 8 bolt pattern is a no-go.
CHRYSLER 300 (1966 - 1971)
CHRYSLER CORDOBA (1975 - 1982)
CHRYSLER FIFTH AVENUE (1983 - 1989)
CHRYSLER IMPERIAL 1974
CHRYSLER LEBARON 1981
CHRYSLER NEW YORKER (1966 - 1982)
CHRYSLER NEWPORT (1966 - 1981)
CHRYSLER TOWN & COUNTRY (1966 - 1995)
DODGE ASPEN (1976 - 1980)
DODGE B100 (1971 - 1980)
DODGE B150 (1981 - 1984)
DODGE B200 (1971 - 1980)
DODGE B250 (1981 - 1984)
DODGE CARAVAN (1991 - 1993)
DODGE CHALLENGER (1970 - 1972)
DODGE CHARGER (1970 - 1978 )
DODGE CORONET (1970 - 1976)
DODGE D100 PICKUP (1972 - 1979)
DODGE D150 PICKUP (1977 - 1984)
DODGE DIPLOMAT (1981 - 1989)
DODGE GRAND CARAVAN (1991 - 1995)
DODGE MAGNUM (1978 - 1979)
DODGE MIRADA (1980 - 1983)
DODGE MONACO (1969 - 1978 )
DODGE POLARA (1969 - 1973)
DODGE RAMCHARGER (1974 - 1984)
DODGE ROYAL MONACO (1975 - 1977)
DODGE ST. REGIS (1979 - 1981)
DODGE W100 PICKUP (1974 - 1977)
DODGE W150 PICKUP (1977 - 1983)
FARGO B100 VAN 1972
FARGO B200 VAN (1971 - 1972)
FARGO D100 PICKUP 1972
FARGO D110 PICKUP 1972
PLYMOUTH BARRACUDA (1970 - 1974)
PLYMOUTH BARRACUDA GRAN COUPE (1970 - 1971)
PLYMOUTH BELVEDERE 1970
PLYMOUTH BELVEDERE SATELLITE (1970 - 1971)
PLYMOUTH CARAVELLE (1978 - 1988 )
PLYMOUTH CARAVELLE SALON (1980 - 1988 )
PLYMOUTH CARAVELLE SE 1985
PLYMOUTH CUDA (1970 - 1974)
PLYMOUTH FURY (1975 - 1978 )
PLYMOUTH FURY CUSTOM (1971 - 1975)
PLYMOUTH FURY CUSTOM SUBURBAN (1970 - 1975)
PLYMOUTH FURY GRAN COUPE 1972
D 100 and D 150 at my pull a part for nine bucks each, I can go get them tomorrow - I thought they were eleven inch brakes when i saw them today - good tip
DODGE CUSTOM 1965
PLYMOUTH PB250 1981
They could be 11" brakes, you can see there's an overlap between the 10" brake list and the 11" brake list. In either case, they will work. I run 11x2.5" drums on my Challenger and my Duster, and have a set on my Dart although it's not on the road.
If you have 15" wheels, it's no concern at all. The Dart has 14" magnums on it, and they clear, although I have heard that not all 14" rims will clear the finned 11" drums.
I wonder if the 11s would work with my rims?
If you have 15" wheels, it's no concern at all. The Dart has 14" magnums on it, and they clear, although I have heard that not all 14" rims will clear the finned 11" drums.[/quote]
you guys on the left coast are lucky... try finding anything but late model stuff round here in the few pick a parts...... ha! other day the second one I tried, said they had virtually nothin, but for a $1 I could go look!?????????? I guess you know where I told him to go???
probably 100 guys a day go there , open 7 days a week, $700/wk, who needs to sell parts!???? ha
Any idea whether these are ten or eleven?
Not without a tape measure. If there's a drum there you can just look at the maximum diameter number cast into the drum.
For the price you said earlier I'd just pull them and bring them home. If they're 11's you won't have any trouble selling them if they don't fit with your 14" rallyes. And I don't know if they'll fit, I only know they fit the Magnum style 14's because I tried it.
Boom! It took a little work but going to the local pull a part is a trip.... there is all kinds of weird stuff goin on at that place..... I swear I think there were hookers workin the back of the yard?
Anyhow - Two Dodge trucks and one had the ten inchers
21.00 including core charge and tax
JB
Nice! :thumbup:
Hopefully you kept the parking brake levers and brake struts...
I am on a budget so I am using the ones off the small bolt plates but....... just in case I took the ones at the pull a part and stashed them in another truck bed so I could go back if I needed them later on.
Wonder if any of the Jeep parts would work as well....since a bunch used Mopar Rear Ends......
