hunt2elk
These tools came out of a closed down Chrysler-Jeep dealership.
Miller 6553 Sandon scroll compressor shaft bearing remover/installer.
Miller C-4090 steering pump rotor lock ring installer.
Miller C-4676-2 clutch alignment tool.
Mopar 2016200211 transmission pump remover/installer tool.
Miller MB991045 trailing arm bushing tool.
Miller 6752 ball joint installer.
Miller 6607 ABS pressure sensor socket.
Miller L-4422 camshaft, intermediate, and crankshaft seal installer set.
Kent Moore J-22191 steering spring compressor tool.
Miller L-4447 bearing puller.
Miller SP-5142 axle shaft bearing remover/installer tool.
Miller C-3742 tie rod end puller.
Miller 990776-A front axle dust cover installer.
$40.00 for the lot shipped in the USA.
