14” SBP steelies work on 11” front disc brakes?
hula
Norman,Oklahoma
Wanting to put 14” SBP steelies on my 1972 Dart with 11” four piston disc on front. Are they compatible?
With stock brakes, your car came with 14" so yes they should fit
This is a 14 x 5.5 stock Formula S steel wheel. There is 12" of clearance inside the wheel. Hope this helps.
Yes, they will work. My sons valiant has the factory 14"sbp steelies on his 4 piston 11" disc brake 1971 valiant.
