[FOR SALE] 17" thrust Wheels
Oh ya, those wheels look fantastic on that car! I guess that's why I also put the same wheels on my 71 Scamp. They fit pretty good on the factory suspension although I had to open the center hub register on the wheels a little bit to fit and used a 1/2" spacer for the front to keep the tires from rubbing. GLWS
Ill check when I get home, They are on my 74 Scamp, not sure if they still had the small bolt pattern in 74, and ill check the width also, thanks
What width are the wheels?
Im not really sure, maybe 71scamper knows alittle more.
I have the factory Moostang wheels, which are the same exact ones as displayed above, Ford just put their own center caps on them, and they are 8" wide. You can also get the 9" wide for the rear if you clearance the wheel wells for them. The 9" wide was optional on the higher end models of the Moostang.
Yes they had small bolt pattern in 1974. My 1975 Duster had small bolt pattern wheels on it when I bought it from the original owner but if these are mustang wheels they should be big bolt pattern.
71Scamper and Holmes thanks for the Info. I was able to pull them off this weekend and measure them, Big Bolt pattern!
Price is dropped to $400
