ssba
Has anyone tried using the 172 tooth flywheel in a scatter shield on their A-body?
This is what I have:
68 barracuda Hemi k- member and mounts
ansen blow proof bell (similar to Lakewood but takes the earlier fork boot) 69ish?
Scheifer aluminum flywheel 172 tooth & scheifer aluminum 11" pressure plate
Aluminum 18 spline 4-speed from early 70s
I have learned this flywheel requires a factory direct drive Hemi starter from 69 or
a Rob Carr(spelling) clockable solenoid aftermarket race starter.
Does anyone know if this will or won't work in a A-body. I believe the 172 flywheels only came factory in the 69 hemi b-body.
I don't want to purchase a starter to find out it won't work for some reason I'm not aware of.
Neither of these starter options are inexpensive as far as starters are concerned.
Hope someone has been here before me to steer me in the right direction using these old school out dated race parts.
I wanted to post a few pictures to help out but they must not have been sized correctly.
