Dartconv64
New Member
Currently has new crate engine 360 magnum installed and recently rebuilt 727 automatic transmission. I was running it with a 440 before engine went. Very solid car. Roll cage, subframe connectors, and super stock springs relocated to allow a slightly larger tire. The dash redone with new white face mopar gauges. I have a set of rechromed bumpers and a pile of new parts that go with the car. New reverse lights, tail lights, door handles, weather stripping,etc. All of the trim that was pot metal I had powdercoated to match the car.(I have headlight trim rings,trunk trim piece,front grill,etc.-all in perfect condition). B & M ratchet shifter. Battery relocated to trunk. New top motor installed. Hood is in my garage, I removed it to avoid damage while finishing. I also have a couple of sets of wheels and tires that go with car. Front end has all new poly parts. Headers, engine accessories, and carb or fuel injection are all you need to finish. I was hoping somebody would want to finish and drive this car rather than parting it out. Car is located in Clearwater, Florida. I have clean Florida Title in hand and have owned this car for about 30 years. I also have a 440/727 combo available that has all accessories, tunnel ram and headers if you want to put it back to the way I ran it before.
