[WANTED] 1965-1966 Barracuda 14" wheel cover
carbufbruce
Member
Vancouver, WA
Rating - 0%
0   0   0
I need at least one 14" Barracuda wheel cover- the exposed lugnut style. I can use either year as I have other center sections to match. The 13" and 14" covers look the same from the outside, but the 13" ones measure 12 !/2" across the clips and the 14" ones 13 1/2" across the clips on the back side.
Thanks,
Bruce
I may have one. I will look in the garage tomorrow in the daylight. The easiest way to tell is a) the valve stem on the 14 inch is on the edge of the break in the metal where the 13 is below the break or b) the 14 inch has a gap between the spring clamp big enough to slide your fingers in, the 13 inch the springs are flush.
What kind of shape does it need to be in?
As far as condition goes, the center is not important as I have 13" centers I can swap in. Hopefully I can find one with the outside in decent shape.
