1965 Barracuda upgrades
brodphish
Green Bay WI
I ordered 15x7 5x4 bolt pattern Mopar steel wheels from Coker. The first one I put on the car was out of round, I did not check the rest as I ran out of time on Friday. I’ll check the rest on Monday then see what Coker will do. If it’s just the one that needs to be replaced I won’t be upset, just get the replacement and move on.
Another problem is the Mopar poverty caps I ordered don’t grip the wheel nearly tight enough. They pop right off with very little pressure. I’ll ask Coker about that as well, but does anyone have a solution to keep them on tight?
Any other good quality options in the 5x4 pattern out there? As we all know options are very limited.
Should upgraded to the 5x4.5 pattern when I had the chance but I had very nice 15x7 ralleye wheels and tires on the car. Unfortunately an unusual shape on the inside rim won’t let the existing wheels fit over the MBM disc brake conversion already installed on the back.
