1965 Plymouth Satellite for trade ONLY
open right now to just about anything mopar for trade I am located about 30 mins east of st. paul minnesota in baldwin, wi 54002 the radiator support was cut was like that when i bought it
yep motor is super fresh probably only 500-700 miles on the motor. Car is very solid body and underneath.....motor is 66' block, 516 close-chambered heads, 11.5:1 compression, flat top mahle pistons, mahle rings, new seats, new bigger intake and exhaust valves, melling pushrods lifters and RV flat tappet cam. New rocker shafts, rockers, and rocker shaft hold-downs, Forged steel crank ground 10/10, stock redone 440 rods, bottom end balanced, main studs, melling oil pump, fastners are all ARP, MSD 6AL ignition, mini-starter, one-wire alternator, edelbrock performer intake, mopar dist., accel coil, holley 4160 elec. choke, heddman headers, TCI rattler balancer, TCI sizzler 727 trans, 12" converter, 2800 over stock....all parts have 500-700 miles on them everything was new....no used parts...THANKS!!
