[FOR SALE] 1965 Valiant Signet Convertible
Teratech
Active Member
Dripping Springs TX
Rating - 0%
0   0   0
This car is currently posted on Craigslist and ClassicCars.com for a fixed price of $5000. There are 24 pictures on Craigslist Austin Tx to get an idea of the vehicle's condition. If there is something specific you want pictures of let me know and I will take and post the pictures you want. I also have a couple short videos of close-up view of the body panels that I can text to you.
It is located outside Dripping Springs Texas. 78620
1965 Plymouth Valiant Convertible Signet - cars & trucks - by owner...
NEW LOWER PRICE!
1965 Valiant Signet Convertible - blue Texas title in hand
The grill is now upgraded to the original Signet grill in much better condition, (new picture added showing the better grill)
Showing 94,945 on nonoriginal odometer, No idea of the true mileage.
VIN 1135156348 Use this to run a title check
225 slant six – recently re-manufactured long block by City Motor Supply out of Dallas, runs like a sewing machine. This means the engine is like new!
3-spd column shift transmission with easy to push diaphragm clutch, shifts smooth
3.23 ratio 7.25” differential – fresh lube and new pinion seal
Blue cloth interior good condition
New convertible top
After market interior lights to include under dash by both doors and a dome light
Most everything is working, fun to drive
This is not a show car. It is a 57 year old driving car. There is always something to fix on it and it needs a paint job. It will pass safety inspection and can be driven as is. I am still driving the car so the mileage will go up. This car should be able to drive most anywhere with it's remanufactured engine.
Starts easy, runs good. The body is fairly solid. Does have rust coming through on the passenger rear quarter wheel well. Was damaged and repaired on the passenger side behind the right door before I got the car. See the rust holes in the trunk in the pictures. Drivers door has a little rust on the front bottom edge. Rest of the panels are in good condition. The windshield has a single crack from top to bottom. There are no rust through spots on the floor pan, sub frames or suspension areas.
Some trim pieces have been replaced. The next project I had planned was to remove the doors to rebuild the hinges, clean and lube the mechanical parts. After the doors were fixed then get the body and paint work completed.
Reason I am selling is I found the same year car with a V8, auto trans, power steering and power brakes. A car my wife could drive.
The sound system in this car is NOT part of the sale. I will be moving it to the next car. The sound system includes the speakers, speaker boxes, the radio, the mounting box for the radio and speaker wires.
