1967-76 Dart Duster Demon Trunk Floor Pan Panel 1PC " Patch " A-body , this is a new piece but shelved for over a year, I had bought for mine but I needed the full piece as mine had rust on rear lip , this is not the full piece , it does not have the rear lip area that butts to tail area , if you have one that is solid in that area then this will work for you , so please make sure you want this piece before buying , I started to install it when I encountered needing more at the rear so removed and bought the full piece , has very light surface rust and a tack weld cut loose , but it is a new patch piece , will sell for $190 , would prefer not to ship dur to cost , so its in central kentucky , the first picture shows it stored on a shelf , did not try to get down yet , the 2nd picture shows what it looks like when I bought it
