[WANTED] 1967 Dart engine harness complete
67 Cuda,Valiant and Dart are the same. The a/c part can be added to a non a/c harness
Thank you for the info and I forgot to mention this is a 360 v8 with a 904
I may end up going with the Street Rod set up if I cant find a solid unit,
I have one out of a 68 but i'm not sure if it was an AC car or not. What should I look for to tell that it had air?
Can you post or send a few pictures to ********
Email address deleted by STAFF
For the most part a wiring harness has every wire for every situation. You just do not use what you don't need
