1967 Dart GT Accelerator Pedal Assembly: I’m a Newbie So Don’t Laugh…
OG67DartGTC
Member
Arizona
I have a 1967 Dodge Dart GT Convertible and I’m having an issue finding out what this part is on the accelerator pedal assembly and where I can get one! I’ve been searching on interweb with no luck…please take a look the attached pics and let me know what this is and how I can search to find this part! Thank you all in advance…
It's a spring to keep the pedal pointed on the right angle. And a bit of anti rattle.
I'm not sure if they are reproduced.
Start a wanted ad, the assy is the same on A bodies 67-70 ( probably thru 76) as far as I know
Thank you sir…I looked it up in the 67 Parts manual and all it says is “Clip 14-01-8”…I appreciate your quick response!
You could probably make one from spring wire.
I mistook the clip that holds the pin into the gas pedal for the spring. The clip 14-01-08 keeps the pin that the pedal pivots on in place
