68Dart500
I've got a few things I'd like to see about getting rid of from my 1968 Dodge Dart. I've changed it over from an Auto to a manual and also upgraded the rear axle from a 7.25 to an 8 3/4.
All prices are OBO. Not really sure what some of the stuff is worth so was throwing out a number. Paypal via F&F or Cash in person. Over 500+ 100% positive feedback on Ebay (hemidartguy).
904 Transmission- Shifted perfectly. Took a short video on its last trip before I pulled it out a month or two back. Torque convertor looks newer. You can have that too for free w/trans if you want. Asking 150 plus shipping
A-Body Console Floor Mounting Brackets and shifter w/linkage 1968 (likely other years too)- I was careful to grind the welds off when removing them so they can easily be welded back on. Shifter functioned perfectly. Chrome is all in good shape except a tiny spot on the top button has some wear from use (see picture). SOLD
Lokar kickdown cable w/brackets- removed off my 1968 Dodge Dart. Worked fine. Easy to adjust. SOLD
Aftermarket 6 blade fan-20 plus shipping
7.25 Rear Axle w/2.94 gears (open diff). Brakes are new as of a year ago (wheel cylinders etc). Pinion seal leaked just a drop or two so you'd want to replace that when you swap this in. Asking 50 plus shipping
