[FOR SALE] 1968 Barracuda Fastback with Barris kit
Littleblue
Member
California
Rating - 0%
0   0   0
1968 Plymouth Barracuda Fastback Barris kit Restomod.
5.7 Hemi Gen3 with Comp cam/lifters/valve springs, and MDS delete. MSD ignition coils, TTI headers, Holley pan, Holley alternator and relocation brackets, Holley Terminator X Max computer. A833 manual transmission with Lakewood aluminum bellhousing, hydraulic clutch, McCloud performance puck style clutch.
QA1 tubular Kmember, tubular upper control arms, 2 way adjustable front shocks, adjustable strut rods, boxed lower control arms, Polly bushings, and front sway bar. Espo rear springs on a custom ford 9” rear with 3:55 posi, adco rear sway bar and Cal Tracs traction bars. Bolt in sun frame connectors also installed.
Close ratio Bergson power steering box. 4 wheel vented and slotted power disk brakes, 4 piston front, single piston rear with integrated parking brake.
New wire harness from front to rear with mini fuses. No fender tag clear title.
Would consider trades for 64-67 Dodge/Plymouth of equal value/ or projects with cash on top. Reasonable offers will be considered, asking $45,000 located in Gorman,CA.
