[FOR SALE] 1968 Dart 440 Superstock Drag Car Project
Jon Litsey
Member
Redding, CA
Rating - 0%
0   0   0
The time has come to let this project go to someone that can finish the vision! I need the space and just can't seem to get to this one.
-Roller Mini-Tub Chassis (Mini-Tubs Need finish Sheet Metal)
-Original 6 Cyl Car w/ 6cyl K-Member
-All Original Glass, Dash, Wiring, bumpers in lncluded
-Super Straight Body with no rust. (Minor Ding Left Front Fender-Shop Incident). Floor pans Replaced
-Chris Alston 8 Point Cage (Not Installed)
-Cal Tracs Rear Spring Set-Up
-383 Short Block (Rotates) - Needs to be inspected (was going to be the initial start-up motor and then install the hi-po 440)
-Correct Miloden 440 Swap Oil Pan
-SSBS Disc Brake Conversion wA-Arms
-Holly 850 CFM Carb
-MSD 6AL (New)
-MSD Distributor (New)
-New US Car Tool Sub Frame Connectors (Not Installed)
-New US Car Tools Torque Boxes (Not Installed)
-Fuel Cell
-Battery Box w/Push-Pull Shut-off Switch
-Fender Well Headers
-Fiberglass race Buckets
I believe I have (but haven't found them in the shop yet!):
-Schumacher 6-cyl to 440 Swap Motor Mounts
-Superstock Rear Spring Relocator Kit
-Dog Dish Hub Caps
I also have a Ford 8" W/Rear Discs rear end and a Powerglide (Both need to be gone through) that I can throw in for the right deal.
Asking $5,500 USD
Jon Litsey (no phone numbers in public forums)
If interested, please call or message and I can email all the pictures.
