[FOR SALE] 1968 Dodge Dart
Axiom
Member
Texas
Rating - 0%
0   0   0
1968 Dodge Dart
318 Magnum w/ long tubes
727 with shift kit & 3k stall
Power steering
Front disc / rear drum
Manual brakes
Ford 9" with 4.10s
$11,000 OBO
Originally bought a few years ago to update and restore. Had a very stout 387 built for it (will also be for sale soon) but priorities have changed. Current engine and trans are good with a Holley Street Avenger. Did run / drive when parked but had a few lighting related electrical gremlins. Front floor pans should be repaired/replaced. Body panels are all steel. Car is solid.
Ripped out all of the old wiring, carpet and began to put in a American Autowire A-Body Wiring Harness and X-Mat sound deadening. Been sitting ever since. Wiring kit will be included with the car as well as the headlight relay kit. Wire up the fuel pump, starter, ignition and change the oil, she'll run. Wiring is in place for a trunk mount battery. I have a Dakota Digital HDX-2018-K gauge kit and display that can be included for a fee. Have the compass/air temp sensor module that goes with the display. I believe I have a GPS speedometer interface that pairs with the display as well. Also have the original heater box.
Car is located in south Texas. Edinburg area.
What is missing for the car?
Please post pics of the parts that come with the car.
The gauge panel is not for an A-body Mopar, unless you have a different dash?
All the parts to make it a running, driving car are there. Just add labor.
The parts that come with the car are in the current pictures sans heater box and tail lights. Both are sitting in the garage.
The cluster is universal and can be made to fit any dash you want fairly easily.
