1969 barracuda ball joint problems
oldnew
Active Member
St. Louis
Rating - 0%
0   0   0
what could be the problem/solution when tightening an upper ball joint to an upper control arm? it is snug, but does it need to be really tight?
it needs to be very tight, if not then your threads are messed up--- either tighten the ball joint in & tack weld it to hold or look for another control arm. Lawrence
