MoeStoner
Member
1969 Dodge Dart 2 door 270 Custom Hard Top V8 Series, brought from the origional owner! Has origional broadcast Sheet. No Rust Anywhere!
Origional paint except the left front fender that was repaired before I owned it, the fender has faded
Vin# 1H23D9E108195
124240 miles odometer shows 24240 I must assume it has turned over.
318 V-8 Brake HorsePower over 200@4400 RPM
Factory Air Conditioning (works)
Defroster and Heater (works)
New Vaccum A/C,Defroster,Heater Controler
Completed Valve job where hardened exhaust seats where installed To accommodate unleaded fuel and new exhaust valves as needed, replaced all exhaust guides.Cyl Bore looks real good, no ridge on cly walls, does not smoke on start up or when running
Radiator boiled out
New hoses and belts
New shocks front and rear
New windshield & Rubber Gasket
New trunk Mat
New turn Signal switch
Dual exhaust with FlowMaster Mufflers
10" Drum brakes front and rear
Power Steering,Installed remanufactured Steering Box
14” BF Goodrich Tires with Dog Dish Hub caps
Stock Thump Wheel Am Radio
Have all receipts to support all work done on this car.
Asking $10,500 or reasonable offer.
Vin# 1H23D9E108195
Radiator boiled out
New hoses and belts
New trunk Mat
