1969 Dart rear window crank gasket
1969dodgedart
Big Block 440
Ontario,Canada
Not sure if the squirrels ran off with or ate the rear window crank shim/ gaskets ( just pulled box out of my shed ) but does anyone know if the 69 dart came with those ?
Are you talking about the large contoured plastic washer that goes between the crank and the door panel?
They are available aftermarket.
My 67 dart has flat ones, I never saw contoured ones till now.
