Mopower 74
Member
1969 Dodge Dart Custom. Car is not complete. F8 green. Body is solid.
Eatmon racing engines R5P7 engine 800 HP I bought this engine direct from Eatmon and have not ran it
GForce clutch assisted GF5R transmission, McLeod clutch, flywheel, and hydraulics, Quicktime bell housing
Moser fabricated 9" 40 spline axles with Spool
Hemi Denny Kframe and front suspension, wilwood disc brakes all the way around
Mini tubbed Caltracs with mono leafs
12 Point roll cage, aluminum rear firewall, Kirkey aluminum pro street seats with covers
AutoMeter cobalt gauges, K&R performance super duty wiring kit, Racewire Turn signal/lighting/horn relay kit
Weld racing wheels front and Champion Wheel single bead locks with 275 radials in the rear
Car needs to be wired (I have wiring kits), right header needs to be modified to fit in a Abody, dry sump system needs to be plumbed (I have oil tank), fuel system needs to be plumbed (has 15 gallon fuel cell in trunk, I have carb for this engine, and it has a mechanical fuel pump on engine), Clutch hydraulics need to be plumbed, needs a drive shaft, needs a starter, and needs a clutch pedal assembly.
All parts are new. No time to finish the car Price is $30K. Pm me with any questions Located in Avoca NY 14809
