[SOLD] 1970 340 block and main caps
boilermaker
toronto
Rating - 0%
0   0   0
1970 FW340P new cam bearings and frost plugs. Block bores at 4.067". May need a bore. $500 obo . Pick up only.
The FW340 is the engine serial number & is not car specific.
The partial VIN was stamped after that, it is on a pad about 3" long on the passenger side of the block right below the coolant drain plug.
There is this after the fw340P304800204.
I was told it came from a '70 Cuda.
1970 Cuda 340 partial VINs could start with;
0B or 0E & then 8 numbers.
