Mossback
Member
1970 340 disassembled stock bore . Have all parts plus extras. Complete 1970 340 TA heads 2.02 - 1.60 . With M/T valve covers ,. Complete 1970 340 stock heads 2.02-1.60 , with stock valve covers . 2 camshafts with lifters , . Isky, 310 hyd, with lifters ,like new. GK 324x324 x 600 lift ,solid lifter . Milodon gear drive ,. Mallory super mag ,with Moroso cable tack. Plus Acell (points type) distributor with extra points and ., condenser . Complete set of 1970 340 stock pistons ,. Complete set of TRW 12.5to1 forged pistons ,with stock rods ,. Milodon ,Hemi oil pump ,with deep sump trap door oil pan for a rail . Milodon deep sump oil pan, with pickup . For a A body . , Zoom flywheel , pressure plate ,and disc . This assembly was matched balanced . Few run's on it ,. SEMA approved blow proof bell housing ,with back plate,. 1970 aluminum bell housing,. Matched pair of 660 Holley carbs , Holley 110 gph fuel pump , Hydra link hydraulic linkage ,. Eddelbrock TR5 tunnel ram ,. 1965 Barracuda4 speed trans, with Vertagate shifter , like new ,. Long tail shaft 4 speed parts trans , it needs work ,. Shortened 3 speed trans ,. was set up for a rail ,. Zoomie headers . Also have extra valves springs retainers , etc,. Thank you for your interest ,i have a assortment of pix, plus. a digital video of the magneto working ,asking 4500k obo ... You wont be sorry. i am located in Grand Rapids MI.... MOSSBACK
