CGrieve
Active Member
Was cloning to a demon, I don’t have the duster front end.
1970 steel crank 440, tti headers, Torker intake, 850 race demon, adjustable rockers, double roller t/chain, fluid dampener balancer, unknown cam, windage tray, 440 source fuel pump and rod, electronic conversion with tach drive dist. 60lbs oil pressure at idle
A833 4 speed, center force clutch, hurst shifter. Brewers bell, Mancini z bar, reverse light switch is seeping.
8-3/4 3.55 open, but have suregrip diff to go with car
RMS spring relocation just done, Mancini unbolts and shock plates
CE shocks all around
BBP front discs, rear is BBP also
15x10 back wheels with new 295/50
14” fronts with new tires
New fuel tank and sender, new 3/8” fuel line
New MC and rubber brake lines, pre bent lines for axle, and drivers side caliper.
New driveshaft with spicer joints
Has clean open KS title
Needs lower qtr work, passenger floor work (I have new full length pan to go with), passenger side upper trunk gutter corner has rot (I have replacement cut out of a rust free car), spare tire well has some small holes.
Frame, torsion bar mounts are nice, trunk extensions are nice.
Running and driving project
$8500 for sale not on sale.
