el5dart
intrument cluster dated Dec 1970. pins on boards are good. bezel is good just needs chrome redone. woodgrain looks good. appears to have 48561 miles and all numbers line up so it could be original mileage. i bought this off of ebay but did not use it.
tested the dash out and speedo moves when you spin it, dash lights worked, as well as hi beam, brake, oil and turn signal lights. amp meter moves when power is applied. temp gauge responded and fuel gauge responded as well
$150 shipped to your door in the lower 48 states. or if your close to memphis tn. you can pick up for free.
paypal or usps money order accepted.
