migsBIG
If your looking to put a nice V-8 engine in your muscle car, this could be what you need. Super nice 1972 360 engine from a grandma fresh car with around 100k miles on the odometer. Car was hit on the side, so none of the drivetrain was damaged. Car in the last 4 months has had a full service done to it, including almost $2500 worth of work done at Ace Fuels including removing and fixing any and every leak there was ok the car, so fresh gaskets and a full service was done. If you want to conver a street rod or truck, this would be perfect for you 360 motor is the first year they offered the engine, very strong for 2 bbl carb like a 340 (you can convert to a 4bbl for more power). Still in car so you can see how nice it runs and has no leaks. Now if you look around, most 360 for sale are the thin wall, smother low compression ones, this one will sip 87 octane and still have the power to move a big car or truck around.
Since this is being sold as a conversion for a car, it comes with all the parts to help make your car swap a whole lot easier. Parts included:
360 engine from air cleaner to oil pan
360 motor mounts
26in heavy duty radiator with fan shroud
Power steering pump
Altornator
air conditioning pump and lines incase you want cold air in your car
Heavy duty 727-A automatic transmission w/linkage
Distributor
Tranny mounts, heavy duty drive shaft so you can have it cut down to your cars length
Engine compartment wiring harness
Factory exhaust manifolds (ones on the car are not factory, but I have the correct ones with it) and comes with all the mounting bolts to put it in your car.
Price for this sweet set up is only $995 firm.
If you don't need the heavy duty radiator, 727 transmission, drive shaft and motor mounts, then I can discount $200 from the price.
Car also has a new duel exhaust system with Flowmast chambered mufflers that was installed 3 months ago that could be included for an extra $100 so you can have it modified to put on your car (probably cheaper than having a muffler shop build you a new system anyway).
360 motor mounts
Power steering pump
Altornator
Distributor
