1971 Duster
Member
Hey Guys,
Need your help.
I just picked up a '72 Demon - it needs a lot of TLC, but has potential.
Got some questions regarding backspacing and bolt pattern for wheels and tires as this car has been backhalfed and narrowed in the rear. It's a 340-4spd.
The current rear tires are 295/50-15 and need to be replaced. Also, the 295 profile is not wide enough. I have 17 inches from the frame to the outside of the rear fender - so I have pretty good space to mount wide tires.
However, I'm not sure about the bolt pattern and backspacing I should use since the car has been backhalfed.
When I measure from the top of the rear fender lip to the ground = 27 inches. Granted I may be able to raise the rear of the car higher - not sure. Keep in mind, having a back-half car is all new to me, so thanks for your patience with my questions.
Left side rear tire
Right side rear tire
Back Half
Pic of Car
Need your help.
Left side rear tire
Back Half
Pic of Car
