[SOLD] 1972 Duster brake distribution block fits others
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
Took this off a 1972 Duster. I cleaned it and media blasted it. $50.00 Free shipping in the USA.
Fit 67-75 A body
67-70 B body
I tried to determine. The car had 73 up BBP disc brakes. According to Year one, this one can be found on either.
It appears to be a disc/drum prop valve. The brass fitting on the top, with the yellow stopper in it is always on disc brake brake cars. Drum/drum valves do not have that fitting. I think it may be called a hold off valve or fitting? Hope this helps. If anybody needs a pic of how the lines run, I have a cheat sheet I drew up years ago....and it's pinned up in my basement. I could text a pic if needed.
