68GTconvert
1972 Plymouth Scamp
This is a project car with a strong running 318 with edelbrock performer 4 barrel intake and edelbrock carb. It starts right up.
The trans is a 727 that slips a bit but i drove it home. I think the rear wheel cylinders are locked up b/c I can't get it to move very well in reverse.
The interior seats are in pretty good shape.
Front disk brakes.
Rear 7 1/4 with sway bar
Small bolt ralley rims with good BFG's.
Has the trim in the trunk.
The rear panel was cut out b/c of typical vinyl top rust. I have the rear window and a replacement piece to weld in place.
Also the passenger window is broken but i have a replacement.
This is a running project with a california title. It will need to be towed.
I have more pics if you want them.
$1500
Front disk brakes.
$1500
