[WANTED] 1972-up Emergency brake stuff
MrBelvedere2
Sacramento, CA
Need 1972-up A body emergency brake hardware and cable, I have the main cable and the cables that go to the rear brakes themselves, I need everything in-between that. Thanks!
are both of the rearend to frame brake cable on the driver side of the car or one on each side?
one on each side, although i have them installed already. just need the cable and hardware in-between those and the main cable that is under the dash with the T handle. Thank you.
Im pretty sure I have all that stuff plus the cable and I have a dart I can test fit it to. please indicate parts you don't need
