Posting for a friend, not mine. Wanting to sell as a package deal and doesn’t want to split up components. 1972 casting date 340 believed to be from a totaled out ‘73 roadrunner. Sealed Power .040 over forged pistons, .023 positive deck, bores look good. It has been in long term storage and has an unknown build history, so it would be advisable to go through what is there and double check clearances and Ring gaps. Crank has been turned 10/10. 1973 cast crank but has a 318 zero balance damper on it, so not sure about Edelbrock Endurashine Air gap intake, ARP head bolts. A complete set of X heads with Milodon stainless valves and what appear to be stock 340 red stripe springs, and a complete set of freshly bushed 273 rocker arms with bananna grooved shafts. Used Comp 274HL .525 lift cam included, but will need lifters. All gaskets and both truck and car pans and windage tray included. HEI ignition distributor. He’s asking $3500 for everything, but may negotiate.
